Removing Rear Deck
Old Aug 15, 2007 | 01:10 PM
xerexb's Avatar
Default Removing Rear Deck
Alright I have an '03 A4, I am trying to remove the rear deck and I am having a heck of a time. Here is what I have done so far.
I have unclipped the two (2) clips in the front
I have pulled out the speaker grill and and undone the 4 torx screws
The problem is the grill pulls up a little, the issue is it does not slide forward...... WHAT AM I MISSING!!!!!!!!
Any help would be greatly appreciated.
Old Aug 15, 2007 | 02:15 PM
techbod's Avatar
Default RE: Removing Rear Deck
edit: wrong car that was for the A3
A4 data to follow
Old Aug 15, 2007 | 02:18 PM
techbod's Avatar
Removing and installing bass loudspeaker -R100- (Saloon) – Switch off all electrical equipment. – Remove ignition key. Removing – Remove the rear shelf:. – Unscrew 2 bolts -4- (from rear shelf side) (2Nm). – Unscrew 2 bolts -2- (from luggage compartment side) (2Nm). – Unplug electrical connector -1- at bass loudspeaker -R100--3- and remove loudspeaker -R100--3- upwards. Installing – Installation is performed in reverse sequence.
[IMG]local://upfiles/12092/26B6BEF8B1B141D79728CC3FC743BC16.jpg[/IMG]
Old Aug 17, 2007 | 01:28 PM
xerexb's Avatar
After messing around with it, after popping out the four clips on the front and taking out the four screws you also have to remove the A pillar and the D pillar to remove the rear shelf.
Just thought I would let everyone in case anyone else goes through the same ordeal.
BT5150
Apr 12, 2011 12:37 AM
rhohmann
Feb 24, 2011 11:37 AM
Tourbo24
May 27, 2010 06:01 PM
edge19lw
Mar 25, 2007 05:00 PM
arb
Jan 25, 2007 10:07 PM
