Replace Headlight Bulbs on 2002 A4
Old Nov 15, 2005 | 02:02 PM
kaklexicon's Avatar
Default RE: Replace Headlight Bulbs on 2002 A4
Dammit, sorry wrong post.
Old Nov 15, 2005 | 03:20 PM
S_R_N83's Avatar
ORIGINAL: kaklexicon
haha that came outta no where
Old Nov 16, 2005 | 04:40 PM
pdlh's Avatar
Hi donm3ga,
My right hand headlight bulb went a day after I purchased my A4. Audi UK wanted £10 for the bulb and £20 to fit it (cheeky buggers). It is possible to change the bulb without removing the headlight. You need nimble fingers. Once you have moved the metal clip out of the way you can then remove the black plastic cap on the back of the head light. using touch you can undo the clip holding the bulb in place. A bit of wiggling and it is easy to change. When replacing the black cover on the headlight be very careful to not drop into the bottom of the wheel arch/front bumper. From experience it is a right game trying to fish it back out.
Good Luck
Paul . . .
Old Jan 8, 2006 | 11:23 AM
ChristopherPovey's Avatar
ORIGINAL: pdlh
Hi donm3ga,
Good Luck
Paul . . .
I've done this before. Dropped the metal spring clip that hold the bulb in place. I have a 2004 A4 Cab, which seems to have 2005 light clusters! Anyway I could not get the wiring connect off for love or money. The clip fell of down inside the engine bay! But by pure fluke it landed between the bumper and engine cover so I grabbed and pulled it through the gap! To avoid losing anything lose (again) I stuffed the area under the light cluster with old towels. Anything that falls then drops on to the towel and it can be rescued!
Just out of interest is it possible to remove the wire connecter? There is a square hole on the top of it and I tried to push a screw driver into it but it was not going to release it. In the end I removed the air in take tube and pulled the light cluster out as far as the cable slack would allow. This is fine for change the dipped beam, but it will be harder for the full beam and indicator bulbs!
Old Jan 14, 2007 | 04:37 PM
wolfdog's Avatar
I found this thread in a search and think this is a good place for my question.
I'm in the middle of replacing my low beam bulbs (halogen) and can't get the driver's side assembly out. Yes, I know there are 4 torx screws and you remove the 2 on top but only loosen the two on the back. The passenger side came out so easy but the driver's side is stuck. I pull the thing aand it feels like there is something on the bottom of it keeping it there. It just won't budge.
Anyone had this problem? Any ideas? Thanks.
Old Jan 14, 2007 | 07:46 PM
CRAZYHAWK's Avatar
On the 2001, B5, there are 3 T-30 torx screws. The one
on the bottom is accessed through a hole in the fender.
A 1/4" T-30 bit is needed. A 6"extention is alsoneeded.
Old Jan 14, 2007 | 09:56 PM
wolfdog's Avatar
Thanks for the effort but I have a '02 A4. The stupid assembly just won't slide forward and I can't figure out why. It really feels like there is something on the bottom keeping it in place. I have unplugged a bunch of wires and such and I know that's not the cause. Well, if anyone has experienced anything like this, help would be appreciated. I'm going back out there tomorrow to try and figure it out. I swear it feels like it's fastened in there somehow. Thanks.
Old Jan 15, 2007 | 01:44 PM
  #18
CRAZYHAWK's Avatar
If it is fastened at the bottom there may be a torx screw holding it.
Get a flashlight. Check for a hole in the fender, and look down it
for the screw.
Old Jan 15, 2007 | 03:29 PM
  #19
wolfdog's Avatar
Whew, got it out finally. There are indeed only 4 torx screws and I had done that part correctly. It was getting hung up on the bottom but the only thing I saw that might be it was a 3-4" bead of caulk or sealant or something. I wound up just trying to pull it out and it gave up after a while.
Old Oct 2, 2007 | 12:42 PM
  #20
shaf's Avatar
I just did it on my 2003 A4 1.8T today ... once you figure out where the screws are, it's easy. Trick is to get the right tools ... a long screwdriver! Otherwise you can't reach the torx ... it's so freaking cramped in there. The lights assemblies in there are very simple and easy to replace.
sleshnyc
Feb 3, 2012 09:42 AM
ppgoal
Feb 4, 2011 12:29 PM
JIMC64
Mar 20, 2008 08:48 PM
cantdrive55
Dec 22, 2007 10:02 PM
donm3ga
Jul 5, 2006 01:20 PM
