replaced coolant senor..many qs?
Old Dec 8, 2007 | 02:36 AM
johnstef's Avatar
Default replaced coolant senor..many qs?
i went on a 5 to 10 min drive and the temp barley went up ( though its 35 degress out). When i took the sensor out to replace solalnt gushd allover the place, do i need to bleed the system to get air out from the coolant. Also im under the min mark on coolant, but no light have come one and there is still enough to cover the hose connect to the tank, is this still bad?
Old Dec 8, 2007 | 07:11 AM
chaos92287's Avatar
Default RE: replaced coolant senor..many qs?
you dont need to bleed the system unless your replacing all the coolant. and if the coolant is under the min mark fill it up with distilled water water or g12 until it hits the max mark. running it under that will cause it to heat up faster
Old Dec 8, 2007 | 01:44 PM
johnstef's Avatar
ok how long does ur audi take fore the coolant temp to go right in the middle?
Old Dec 8, 2007 | 01:51 PM
auditech79's Avatar
ORIGINAL: johnstef
Depends on the exterior temp and how hard your driving the engine, it should take around 5 minutes of normal driving time to heat up.
Old Dec 8, 2007 | 10:12 PM
johnstef's Avatar
so idk know what rly going on now. I replaced the coolant sensor and it still doesnt rly warm up properly.
Old Dec 8, 2007 | 11:25 PM
auditech79's Avatar
Its fine dude, its damn cold where you are. If its not going over the center mark then the thermostat isn't messing up and the water pump is working fine.
Our heater cores run coolant through them at all times which makes it heat up longer than lets say a chevy so maybe thats what your used to?
Old Dec 8, 2007 | 11:51 PM
johnstef's Avatar
either its all in my mind but last year in the winter it doesnt matter how cold it was, it went right in the middle????
Old Dec 9, 2007 | 07:51 AM
chaos92287's Avatar
does it never reach the middle? or just take a while to get there?
Old Dec 9, 2007 | 07:57 AM
ImTheDevil's Avatar
Heh, if I idled in traffic for 10 minutes or so, in the winter weather we've got here (20-30 degrees out), the needle would get most of the way to hot. Give me five minutes on the highway at speed after that and mine'll be right back down near the cold peg.
Old Dec 9, 2007 | 12:45 PM
johnstef's Avatar
no i havent seen it hit the middle yet, and it takes like about 10 min to even start moving..so idk, if its working or not. anyway to test it??
