Replacement of Alternator
Old Sep 11, 2007 | 01:09 PM
Mhmara's Avatar
Default Replacement of Alternator
I am going to be replacing my alternator, anyone done. Got pics, and hints please.
Thanks Mike
Old Sep 11, 2007 | 01:59 PM
hiwords's Avatar
Default RE: Replacement of Alternator
wut engine?
Old Sep 11, 2007 | 05:15 PM
Mhmara's Avatar
1.8 T.
Old Sep 11, 2007 | 07:02 PM
Mhmara's Avatar
Please give me some help, pics or what ever you can. Thanks
Old Sep 11, 2007 | 07:27 PM
hiwords's Avatar
http://forums.vwvortex.com/zerothread?id=2553076
hope it helps
Old Sep 11, 2007 | 07:44 PM
auditech79's Avatar
It really depends on what year 1.8T engine you have, the pre 01 engines are a lot harder.
Usually have to remove the fan clutch on the older models and some other crap.
01+ models are easy, just take off the belt, and un-bolt the two bolts, then swing that piece of crap out.
Old Sep 12, 2007 | 03:21 PM
Mhmara's Avatar
Ok, I was just freakin', since I had never worked on an Audi before. And, now I have. The alternator was a easy. It took me 30 minutes from start to finish. Two tricks, be sure to remove the throttle body. The clip for the plug, well you push a small flat head screw driver into the slot along side lift up gently and it slides off. Otherwise easy. The web site kind of helped, so thanks. It really was simple.
Thanks all,
Mike
A4 2000
May 23, 2016 05:09 PM
mapper01
S4
Nov 21, 2013 07:27 PM
rubanokuss
Feb 20, 2010 12:00 AM
havok91
Dec 13, 2009 09:02 PM
jonbelles
Feb 2, 2007 01:21 AM
