replacement of everything almost in susp.
i posted up here not to long about a "knocking sound" coming from my left tire well. and i got a few responses on its either the cv joint or cotrol arms, or struts.
well i was looking into some parts and all i found this link
http://www.autohausaz.com/search/pro...int%20Assembly
its a whole assy
and i already have struts and springs sitting at my house
this sound good? the price? i have a 99 b5 with about 85K on it. is it time?
let me know what you think.
thanks
its a whole assy
thanks
well the full kit from ECStuning.com with HD TRE's is only 499.95 so I say the price there is high. I know the install will be a PITA because of the main bolt on the bearing carrier. If you have everything and your going to do a "replace everything" install, then sounds like a couple of stressful days working with stuck bolts - hopefully you have a mechanic connection that can install eveything for ya
