Replacing turbo?
Old Sep 11, 2007 | 01:47 PM
The Bishop's Avatar
Default RE: Replacing turbo?
It's not really that hard, it's just getting to all of the bolts that is difficult. The only problem I had was the bolt on the turbo support bracket on the bottom of the turbo. The f***er was tight and I ended up stripping it. But once I got the torbo out I was able to get a better angle on it and get it out. If you have done the timing belt already then you shouldn't have any problems.
This would also be the easiest time to do a test pipe as well. Hint. Hint.
ocadam's Avatar
Im not calling you out or anything onepoint8tee. But i did not break any rules.
https://www.audiforums.com/m_35509/tm.htm
But hey were all friends right?
Old Sep 11, 2007 | 01:50 PM
Audi_Skydiver's Avatar
ORIGINAL: thebishop
Haha, If I had the money I would!!! How much are those things again? I need to look around... Also, I am in cali now and how would I get away with it???
Josh
Old Sep 11, 2007 | 01:53 PM
The Bishop's Avatar
ORIGINAL: ThePaintballGuy
Josh
That part is up to you.
Old Sep 11, 2007 | 01:54 PM
ocadam's Avatar
I live in Cali i have heard the fines are alot if you get caught..
Old Sep 11, 2007 | 02:05 PM
onepoint8tee's Avatar
ORIGINAL: ocadam
It was a joke. Based on 100% of your posts I would expect you to play along....? Still BFF's dude!
Old Sep 11, 2007 | 02:07 PM
ocadam's Avatar
Okay good because i did not wanna get in a argument with you. Because i would get destroyed!
Old Sep 11, 2007 | 02:10 PM
  #18
Josh
Ebay sells a TP for $115 shipped, which is about as low as it gets unless ATP or another maker has a group buy/special deal going on. It wouldnt be easy to get away with if they see it. People have talked about rigging a heat shield onto it to disguise it, but you arent going to find a used one that didnt get hacked to hell when removed, and a home made one wont look convincing. Maybe a high flow cat is a better idea?
Old Sep 11, 2007 | 02:22 PM
  #19
Jeff's Avatar
Zombie Defense Force
the night before you start soak ever bolt in some pb blaster or wd-40 and it iwll be easy
Old Sep 11, 2007 | 02:37 PM
  #20
khj677turbo's Avatar
Agreed, expect to really hate that oil return line, and maybe you should wear some gloves since your hands will get torn up. Didnt really help me but hey! Also, if you have back problems, maybe you should get your chiropracter on speed dial.
