Rich or lean
Old Jan 26, 2007 | 12:31 PM
Yerfdog006's Avatar
Default Rich or lean
So I asked the guy at the car shop if he could tell me why my check engine light was on and he said that he got a code that was 60 or 61 and said the engine is either running lean or rich, but his computer could not tell him any more. Do I need to take it to the dealer? Any other guidance or things that I should know. Thanks for the help
David
Old Jan 26, 2007 | 12:40 PM
CRAZYHAWK's Avatar
Default RE: Rich or lean
What engine and year do you have? AutoZone reads the codes free.
60 and 61 mean nothing. Buy a code reader or a VAG-COM and
read the codes youself.
Old Jan 26, 2007 | 12:41 PM
MissionCtrl's Avatar
Check you plugs, if they're real black then you're running rich. As for lean, take a high speed WOT highway run, if you're running that lean you will hit limp mode. He should be able to give you more info than that, I would try taking it somewhere else and see what they tell you. Post your code, the guys here are uber helpfull.
Old Jan 26, 2007 | 04:38 PM
onepoint8tee's Avatar
No dont go playing around much with WOT if you have a lean issue. Limp mode isnt always going to save your ***.I had lean issues last summer and was detonating all over the place and only went into limp mode a couple times because of it. Ended up being a bad MAF for me. Definately get the codes read by a good code reader before you got WOTing. You can kill your engine if you detonate too much.
Old Jan 26, 2007 | 04:48 PM
tractioncontrol's Avatar
Most of the time rich and lean conditions are caused by MAF sensors, clean it with some computer keyboard cleaner.
Old Jan 26, 2007 | 05:23 PM
Jeff's Avatar
Zombie Defense Force
haha if your having lean problems go run at high rpms in wot...after you blow your motor we can tell you what was wrong
Old Jan 26, 2007 | 05:25 PM
quattrosedan's Avatar
ORIGINAL: Jeff
Yeah, I got a good laugh on that one too.
FireEagle170
Aug 30, 2013 05:18 PM
jgood
Feb 8, 2013 12:55 PM
lespaul1921
Jun 25, 2011 08:53 PM
Stoliguy
Jan 27, 2011 06:38 PM
peiserg
Jun 27, 2007 10:46 PM
