ROSS TECH VAG COM
Old Jul 25, 2006 | 10:59 AM
smokeU's Avatar
Default ROSS TECH VAG COM
on the ross tech website, which one do I order? the one that costs $99? or am I confused? is this shareware? what laptop specifications do I need in order to run this? TIA!
Old Jul 25, 2006 | 11:32 AM
dafrazi's Avatar
Default RE: ROSS TECH VAG COM
If you buy the cable from Ross-Tech you don't need to buy a software license. There is a software key built into the cable that turns the shareware version into a full licensed version. If you buy an Ebay knock off cable you will need to pay the $100 for a licensed software copy. You buy and old Ross-Tech cable from Ebay, you will won't to make sure that the cable has the software key built in (it called a dongle); because the old cables didn't have them. I think Ross-Tech started putting the dongles in about 1.5 to 2 years ago.
Any old laptop will run the program. I use a laptop that is about 8 years old and it works fine.
Old Jul 25, 2006 | 11:46 AM
smokeU's Avatar
thanks dafrazi. so I should buy the cable from ross tech. then is there a place where I get the shareware version for free? or does the cable come with that? a little confused so bear with me. but I want to have this vag. I have the obd II scanner but it only turns the CEL off etc.
is our coolant G12?
Old Jul 25, 2006 | 12:53 PM
primo537's Avatar
so is it worth the extra $100 for the Hex-COM+CAN($329) instead of buying the Key-Com interface($229)? If so why? Thank you
Old Jul 25, 2006 | 02:32 PM
dafrazi's Avatar
You can download the shareware version right off the Ross Tech site, that's what I did. The cable may come with a copy but I don't know for sure. I have cheap Ebay cable that I use for reading and clearing codes. I just borrow dan's Ross-Tech cable when I need to do logging and other stuff.
Old Jul 25, 2006 | 04:05 PM
smokeU's Avatar
ORIGINAL: smokeU
is our coolant G12?
Old Jul 25, 2006 | 04:32 PM
new2me's Avatar
Yes it is.
ORIGINAL: smokeU
ORIGINAL: smokeU
is our coolant G12?
Prizmatik
Nov 7, 2012 10:08 PM
Euthanasia
Jul 9, 2008 01:30 PM
DurTTy
Jan 14, 2008 01:34 PM
khaoswing
Jan 30, 2007 01:20 PM
prodrive
Aug 16, 2005 06:22 PM
