Rubbing noise from steering wheel.
Old Aug 25, 2006 | 04:03 AM
b52000a4's Avatar
Default RE: Rubbing noise from steering wheel.
i have the same problem.... i have had it for a while now and it seems to be getting worse...
Old Nov 15, 2006 | 01:06 PM
ddd's Avatar
ddd
ORIGINAL: brrman
You could have the dreaded steering column spring creak if it sounds like its coming from inside the steering wheel itself.
The column has a couple springs in it - expensive as hell to change a $5 part. Try tilting the wheel a little, or telescoping it a little to get rid of the noise. Some have lived with it by doing that.
Does anyone have a diagram of the steering column, i want to do a DIY, its getting pretty annoying.......
Old Nov 15, 2006 | 01:26 PM
techbod's Avatar
most common cause is loose cowling/cover and touches the steering wheel check for missing screws and if too much free play in the steering wheel
[IMG]local://upfiles/12092/46EBEFB18F0C4FBF89E7CDE595C99066.jpg[/IMG]
Old Nov 16, 2006 | 10:53 AM
ddd's Avatar
ddd
will try, thanks......
Old Nov 16, 2006 | 11:20 AM
CRAZYHAWK's Avatar
I sprayed silicone and then white lithium grease, between two rubber
parts in front of the steering wheel. The squeak is gone.
Dallas09
Jul 29, 2008 02:13 AM
dragondesigns
Sep 29, 2006 08:43 PM
a4mad
Aug 21, 2006 09:03 PM
anita
Feb 2, 2005 02:57 AM
