runing ritch? possible???
Old Sep 14, 2006 | 06:09 AM
trailboss's Avatar
Default RE: runing ritch? possible???
The chip is set to what it should be by apr, they dont do changes. The only othe ways would be standalone, or for just fuel a S-AFC. You can get a VAG and data log things such as MAf g/sec primary o2 sensor voltage which can convert to an a/F reading, n75 duty cylcle and alot lot more to but cant change anything there.
Old Sep 14, 2006 | 10:28 AM
quattrosedan's Avatar
You could get the lemmiwinks program like jeff had. but you wouldnt want to start messing with that unless you actually knew what you were doing. And on a stock turbo, dont even waste your time.
Old Sep 14, 2006 | 12:34 PM
Audi42005's Avatar
Member
i put a BOV on my brothers A4 three years ago and it is still running fine. although it could just be luck that nothing has happened. when i put it on it ran lean and would stall, so i customized it so it would divert some air back through and some to the atmosphere for a few weeks, then i vented it completely to atmosphere and it worked fine. since it wasn't one big change all at once, maybe it helped.
CrazyA3
Apr 15, 2008 12:53 PM
albfelix
Jun 29, 2007 01:01 AM
audihere
Apr 12, 2005 01:53 AM
