Running lights problem
Old Jan 22, 2007 | 11:59 AM
akielb's Avatar
Default Running lights problem
98.5 1.8TQA
I finally got around to changing my tail lights back to original and now I have a problem. The running lights on the right side of the car are not working - front and rear. I've changed the bulb in the rear and that didn't help. I looked a little bit more and noticed the front wasn't on either found they have their own fuse - I looked and it was blown. I replaced the fuse - and nothing. I used a voltmeter and I get power through the fuse. Any Idea's??
I get power to the bulb, both front and back - blinker works(front) and brake light works(rear). so its not that I didn't put it back together right. I'll do some more probing tonight with a voltmeter
UPDATE:
Problem fixed - took off harness and notcied that one of the metal lines that powers the bulb was no connected to the board. Bent it back - replaced the fuse again and everything is working.
RGT
Oct 31, 2012 03:21 PM
illegitimi
B7 Models
Jul 24, 2011 12:54 PM
Tuccatucca
May 3, 2010 07:24 PM
Cappachinoo
Jun 26, 2008 02:04 PM
blockp
Jan 30, 2008 01:04 AM
