running a wire from back to front?
I want to get the dice system to intergrate my ipod, though i will need to connect it to the trunk cd player and then run a wire to the front so i can control the ipod. What is the best way to do this? I want it to be as discrete as possible. Thanks.
I've never done it in an audi, but when I installed the sub box and amp in my neon I ran the power and other wires under the rocker panel molding, then behind the "B" pillar panel, up under the back seat, and through to the trunk. you can't see any wires at all in my setup.
so you are running it from trunk to front of car?
i would say as with just about any sedan,
connect your wire to your cd changer, then run it beside/along the side of the seat, down the plastic door sill, under plastic on b pillar, under drivers sill,behind dash/knee pieces to h/u, unless you are trying to take it to the center consol, then under the carpet to center console, there is a diy on running a power wire for an amp on here or audizine
https://www.audiforums.com/m_318162/tm.htm
just do it kind of in reverse
kdcrowe911
Jan 30, 2012 11:46 PM
