s4 door trim. look good?
I need to replace all of those damn door trim pieces and i was wondering if the s4 ones look good on our cars without having any other s4 mods. I found the stock ones for 125 and s4 for 175. just wondering what others thought. thanks
are you talking about the belt line trim ? on the door panel
or like the lower plastic trim on the outside of the door ?
if the second then it wont look right, there will be a gap between the bottom of the trim and the door sill, the s4's are shorter
If you're talking B6 and you mean the outside lower door trim pieces like on my sig pic, then you aren't getting real ones for that price. Even used ones go for almost $300. New is only slightly higher.
Don't do the eBay ones; they are stick-on and not the actual plug n play bolt on ones.
The OE unscrew with two bolts, slide off, and new S4 blades fit right on. 5 second operation. Ebay ones use double sided tape at best; lots of body work at worst.
If you're not talking about those, or have a B5, then disregard.
[align=left] [/align]
Yes i am talking about a b5. so no go on the s4 ones? they look crappy or what?
And to AteUrV8 yes i am anther DSM guy that has come to realize they just dont want to stay together with 420hp. Everytime I take it out I snap an axle or transfer case or something. It is always something with those cars
nismonewf
Nov 27, 2008 08:43 PM
