SeaFoam
Old Dec 5, 2006 | 04:03 PM
GTOrleans's Avatar
Default SeaFoam
So i dropped some seafoam in the tank the other night, all the little knocking and pinging noises i use to hear under hard acceleration are gone, great stuff! i was curious after reading that seafoam diy i think on audiworld, if anyone has left the seafoam in there oil for long periods of time, i just had the oil changed and i'd throw some seafoam in there, but wanted to know if there would be any negative effects by leaving it in there for quite a few miles until i need my next oil change.
Old Dec 5, 2006 | 04:22 PM
ProOnThaSnow's Avatar
Default RE: SeaFoam
You're only supposed to run the seafoam in your crankcase for 2-300 miles. I'd wait untill right before your next oil change, but yes, it does work wonders!
Old Dec 5, 2006 | 04:27 PM
GTOrleans's Avatar
Default RE: SeaFoam
seriously i was rather suprised at how it cleaned up idling and irregular noises. definetely a recommendation from me, ill hold off then on dropping it in the crankcase, and just run it thru the intake.
Old Dec 5, 2006 | 04:41 PM
Default RE: SeaFoam
when you do run it through the intake, you should also change the plugs afterward. Be prepared to have an OBD-II scanner, or vagcom, because it will probably through a code, being as how the o2 sensor will read that there is an imbalance in the exhaust... no biggie, clear it, and go!
Old Dec 5, 2006 | 04:59 PM
wood_e's Avatar
Default RE: SeaFoam
I'd use autoRX in the oil to clean sludge and varnish.
http://i2.photobucket.com/albums/y3/woojo/FILTER.jpg
^ my Purolator L40316 after the clean cycle
Old Dec 5, 2006 | 05:10 PM
onepoint8tee's Avatar
Default RE: SeaFoam
Crankcase treatment thins your oil and long term bad affect is reduced lubrication and scoring of the piston walls from the piston rings resulting in lowered compression. I wouldnt go more than a couple hundred miles with a crank case treatment. Ive also heard that auto-rx is good and maybe safer to use.
Old Dec 5, 2006 | 07:44 PM
GTOrleans's Avatar
Default RE: SeaFoam
sweet, well im just looking to keep it running strong until mid-next year, B7 S4, "oh yes, she will be mine!" btw that means b6 will be for sale in march/april. I'll give the auto-rx a try. thanx for the info.
bshouler
Jul 7, 2010 09:11 AM
badlandz
Mar 21, 2009 12:17 AM
JohnnyS4
Apr 5, 2008 11:06 PM
Shwabmyknob
Mar 3, 2008 11:46 PM
vintravaia
Mar 3, 2008 12:38 PM
