Secondary Air Pump
RE: Secondary Air Pump
Some more information on your car other than you have 35% tint would be helpful in providing part numbers and diagnosing problems.
What CEL are you getting that makes you think you need a new air injector?
ah sorry 1.8t 2001. the reason is because i got the fault code for secondary air injector system and ive already replaced a few parts related. let me find the other post i made awhile back
sorry for the lack of help guys
https://www.audiforums.com/m_199498/.../tm.htm#199735
the thread that was from b4
and the cel #:
P0411
Secondary Air
Injection System
Incorrect Flow
and the cel #:
P0411
Secondary Air
Injection System
Incorrect Flow
yea that is a common one on our cars I had it not long ago myself ended up being my combi valve and the dealer told you to replace the suction jet pump if there is no crack in the l shaped hose and you can blow though the pump that is still fine
goog way to check to see if the air pump is working get someone to turn your car to the on position no start the car but have the accessories on and you get down in front of the car on the passenger side if you here a winning sound your pump is working
