Services
Old Nov 17, 2007 | 12:41 PM
phillyfan1290's Avatar
Default RE: Services
Are the timming belts hard to replace?
Old Nov 17, 2007 | 12:51 PM
chaos92287's Avatar
not really, but its harder than an oil change http://www.audiworld.com/tech/eng35.shtml
and did you change the drain plug washer when you changed the oil? cause they are designed to deform once tightened to create a perfect seal, so you gotta change them out everytime.
if you didn't you might have a slow drip leak from the drain plug
Old Nov 17, 2007 | 12:52 PM
FASTER's Avatar
Tech Slut
if you are lost under a hood then yes, if you got minor skills then not too bad... time consuming either way
Old Nov 17, 2007 | 12:54 PM
FASTER's Avatar
Tech Slut
ORIGINAL: chaos92287
thats why they are reffered to as crush-rings... one time use
Old Nov 17, 2007 | 02:33 PM
yes i did change those plugs and i might change them myself to save some money i myself am a minor under the hood so im ahave help from a few friends that knw more about it thanks for all your help
Old Nov 17, 2007 | 02:41 PM
FASTER's Avatar
Tech Slut
timing belt is a great diy to get better aquainted with your motor and working on it, i suggest giving it a try with a friend that can steer you in the right direction.
Old Nov 17, 2007 | 10:59 PM
cool thanks for you help,
now i got a problem thow when i first turn the car on, it can be cold warmed up anything, it makes a noise like a spinning noise and i looked and couldnt tell where it was comming from any suggestion to what this might be?
also im almost ready to chip it but im not sure if i should i only have 56k miles on it and the engine and all seems really shaking when i open the hood cant feel it to bad in the car can alittle is there anything i can do to make sure i wont have major problems down the road take it to a audi dealer to have checked maybe? but im sure that will be close to the $1000 range
cameron2212
Apr 20, 2025 11:44 PM
sasuga
Jul 30, 2009 02:02 AM
marlonduval
Feb 22, 2008 12:09 PM
AD
Aug 3, 2006 03:46 AM
