She is almost resurected...
Old Aug 24, 2006 | 02:20 AM
  #21
dan's Avatar
dan
Default RE: She is almost resurected...
Yo tom, drop me a line, I need to talk to you about getting some upgraded rods and other internals.
Old Aug 24, 2006 | 03:31 AM
  #22
BadLuckAudi's Avatar
good to see ya back tom, but i think you need a hx45 or bigger
Old Aug 24, 2006 | 10:20 AM
  #23
dafrazi's Avatar
dan it sounds like you want one of Tom's "small" cast off turbos.
Old Aug 25, 2006 | 03:01 AM
  #24
TomRitt's Avatar
Yes it runs! I only changed 1 valve craig, i'm pretty sure that was the only damaged one...I hope, I looked over the others and they looked fine...I guess i will compression test it once its fully together tomorrow. It sounds fine though...just glad it started with no issues
Old Aug 25, 2006 | 03:02 AM
  #25
TomRitt's Avatar
Oh yea lmk Dan, I can try and get you a deal!
Old Aug 25, 2006 | 03:03 AM
  #26
TomRitt's Avatar
Cameron, not sure on the swap yet, the wiring will be easy because it will be on standalone and I already have the connectors, the mount mounts I will be building solid, just not sure on the clutch/fw situation yet
Old Aug 25, 2006 | 03:51 AM
  #27
flyinb501's Avatar
Glad to hear your hangin on to the A4 Tom. Good luck with the project!
Old Aug 29, 2006 | 12:57 AM
  #28
TomRitt's Avatar
well i got the car buttoned up fri night, put 8miles on it, changed the oil, then drove it 400mi up to school with no issues!! Whats a relief The only problem is the turbo exhaust housing is too big and doesnt begin spooling til 7k rpm[8D] obviously I'm gonna through on a smaller hotside to move the powerband earlier
Old Aug 29, 2006 | 01:02 AM
  #29
did you say you had a hx45 hot and cold side, if so you should so a 35 hotside with the 45 cold side to get better spool ya know
Old Aug 29, 2006 | 01:32 AM
  #30
TomRitt's Avatar
well i have an hx40 with an 18cm^2 hotside. The hx35 has many different hotsides available, i used to have a 9cm^2 on my last one, this time i will be bolting on a 12cm^2 housing, or a .53 a/r housing from bullseye who make custom holset exhaust sides
