Shift points..
Old Aug 7, 2006 | 12:11 AM
Karl's Avatar
Default Shift points..
What are you guys shifting at for maximum speed.. IE drag strip..
Old Aug 7, 2006 | 02:55 AM
MilitantGrunt's Avatar
Default RE: Shift points..
Red line.. about 6500rpm.
Old Aug 7, 2006 | 03:01 AM
Karl's Avatar
you actually loose power, and speed by shifting at redline..
Old Aug 7, 2006 | 03:22 AM
onepoint8tee's Avatar
when im in tip and really goin for it i shift at or right before 5000 rpms.
Old Aug 7, 2006 | 03:41 AM
Cameron's Avatar
I've always liked to shift at peak power - 5900 (stock)
Old Aug 7, 2006 | 03:44 AM
jliu's Avatar
I always shift between 2500-3000 rpm, is that too soon? But except the first gear though...I pulled up to 5000RPM and shift to second gear, am I loosing power?
Old Aug 7, 2006 | 03:51 AM
Cameron's Avatar
We are talking about like for drag racing, not day to day driving.
Old Aug 7, 2006 | 03:52 AM
evoic's Avatar
Around 5800, gas to the floor, and ready to shift again as that puppy climbs quick through 1st, 2nd, and into 3rd.
Old Aug 7, 2006 | 03:57 AM
jliu's Avatar
Roger that...I guess for my skill, I'm too early to talk about drag racing, I'm still having problem going on smooth in first gear, any suggestions on that...
ORIGINAL: Cameron
Old Aug 7, 2006 | 04:05 AM
Cameron's Avatar
Just be real smooth on the clutch till you get used to it, after I while you will learn to know exactly where the friction point on the clutch is. You'll get the smoothest driving if you aren't going to 5k rpms in 1st every time you come from a stop light. Just make your goal to drive so smooth the only way people can tell you are shifting without looking is by the engine note.
