shifter goes into tiptronic too easily
Old Jan 10, 2006 | 07:06 PM
98 A4 Turbo's Avatar
Default shifter goes into tiptronic too easily
When my 98 A4 is in Drive, all i have to do is hit a decent sized bump or turn left to make the shifter slide into tiptronic mode. It feels like there used to be a barrier inbetween the two modes that would take some force to be overcome but now it slides right in without any effort at all. Of course, this is nothing more than an annoyance but it definitely IS ANNOYING. Is this a common problem and is there any way to fix it? Thanks!
Old Jan 10, 2006 | 07:55 PM
tip5's Avatar
Default RE: shifter goes into tiptronic too easily
I wish i had the option of switching i have a 97... Oh well guess its good cause i dont have to worry about that.
Old Jan 10, 2006 | 08:06 PM
ORIGINAL: tip5
lol the pros and cons of tiptronic brought to you by Tip5
Old Jan 10, 2006 | 08:37 PM
StevenTownsend's Avatar
never heard of this happening but i don't know if it's worth tearing apart your gearbox to see if it's an easy fix
Old Jan 10, 2006 | 08:38 PM
tip5's Avatar
Old Jan 10, 2006 | 10:19 PM
o i definitely wouldnt tear apart the gear box. i was thinking that mayb if the plastic was taken off the area around the shifter, something may have slipped out of place that would prevent the shifter from moving so easily. I guess this is not a common problem though. looks like im on my own haha
Old Apr 22, 2006 | 03:37 PM
gregulator's Avatar
Any update on this? My 98 does this too, it just flops between auto and tip.
Old Apr 23, 2006 | 04:19 PM
thatguy's Avatar
I always hear about tri ponic shifters .. what exactlly is it ?
Old Apr 23, 2006 | 04:31 PM
audia4bro's Avatar
if you really dont use the tip just put like piece of plastic or like a piece of paper or better TAPE to hold it in place temporarly, until you find a how to fix.
Old Apr 23, 2006 | 08:23 PM
i went to a shop that specializes in audi's and they said that the whole shifter would need to be replaced and that it would cost around $200. Im not tryin to pay that much to fix this just yet so in the mean time, I glued a few layers of car board together that fit exactly into the oval area. I used a few layers to make sure it was not able to slip under the chrome plastic piece bc im sure that would not be good. To use tip, I just take the cardboard out and when im done, put it back it. Its a good temorary fix but it still annoys the hell out of me.
That guy: its Tiptronic. its a sort of manual mode in which the driver can shift the car at will by pushing up and down on the gear selector. Its like a bad substitute for a stick but it still provides some fun once in a while.
