Should I do anything else to my car while it's in for head gasket?
Now that I know my head gasket it bad between Cyl 2 & 3, should I do anything else to it while it's in the shop?
I planned on doing timing belt(water pump, belts, tensioner) and that was about it. But, now that I think about it, I might do more.
Someone suggested finding out how much P & P is going to be. I'll be checking into it. I'm thinking about getting a snub mount, Forge DV, and debating on lightweight pulley.
Is the pulley worth it? And should I even really think about anything else. I don't have that much money to put into the car now that I have to spend $1600 on head gasket and timing kit.
im sure they are already gonna do this but mill the head. incase it over heated.
do you have the 1.8t. and how do you think you blew your head gasket. or how did you find out.
i think mine may be blown too.
I would put a diverter valve on like you said but I wouldn't have the dealer do it. It is very simple to do yourself and you will save on labor that way.
Yeah, they plan on milling the head. That's why it's going to the machine shop. It's only at a local shop, so I doubt they'd charge me much in labor since it'll be right there anyway. The guys at the shop are pretty cool.
Car is a B6 1.8T. I think the car may have gotten a little warm one day with there was no coolant in it due to a coolant leak. I'm guessing that may have caused it. I fixed the leak and then soon after that, it started misfiring. They did a leakdown on it and when they put air into Cyl 2 it came right back out Cyl 3. So it looks like it's just bad between those two Cylinders. I could smell a sweet smell from burning coolant, but figured it was just leftover coolant from the leak it had that I fixed. Plus, the plugs in 2 & 3 had a little bit of white deposits on them like you'd get from coolant.
I would not feel comfortable with a local shop working on my Audi.. At least on a job like this.. Taking appart all that stuff to get to the head.. YIKES! It will probably be a learning experience for them. A lot of local places wont agree to do some work on Audi's. I hope its a good experience for ya. $1600 isnt all that bad of a price for that and the timing belt kit. Too bad your not getting any power gains for all that money.
ORIGINAL: wood_e
If you mill the head you'll increase your compression
I'm not having the head milled for performance though. It's to make sure that any imperfections that may have caused the head gasket to start leaking are taken care of.
The shop is local, but they're an all EURO car shop. http://www.eurotechofholland.com/
Very reputable in the area.
That's why I posted this is to see if a P & P, DV, and lightweight pulley would be worth the extra bucks.
id be careful with the light weigh pully some people have had problems with them on the 1.8t
ORIGINAL: kraylon
i got a light weight pulley on my car and the only thing i noticed is that it reved up faster and that was it really but i got he pulley for free and got it installed for free when i did my timing belt
