should i worry?
Old Nov 6, 2006 | 12:33 PM
keko2004's Avatar
Default should i worry?
i ran my vag-com and did an autoscan. the first thing that came up on address 01 was multiple misfire on 2/3 cylinder. but my car didnt feel like it was misfiring. when the scan was done i cleared the codes and ran the scan again but this time no fault code came up. should i worry about this?
Old Nov 6, 2006 | 12:52 PM
acetrebo's Avatar
Default RE: should i worry?
Just clear it and see if it comes back.
If not, I wouldn't worry about it.
If it does, you will know where to start looking.
Old Nov 6, 2006 | 12:53 PM
kpatz's Avatar
Drive the car for a few days (~40-50 miles) and then scan for codes again. If the codes come back, then there is a problem somewhere (probably coilpacks, plugs, or the ignition module).
Old Nov 6, 2006 | 01:10 PM
keko2004's Avatar
will do so but i have a brand new icu. i had a misfire 2 weeks ago due to the original icu failing. thanksd
Old Nov 6, 2006 | 01:15 PM
kpatz's Avatar
If the codes weren't cleared when the ICM was swapped, they could be leftovers from when your ICM failed.
Recheck codes in a week or two, they shouldn't come back if the problem is fixed.
da604a
Dec 12, 2007 06:10 PM
NeXeA500
Oct 3, 2007 05:42 PM
dfrost
Sep 14, 2007 03:04 PM
qUaTtRoA4
Apr 21, 2007 11:34 AM
