Pulled these codes - to worry or not to worry?
Old Oct 3, 2007 | 12:52 PM
NeXeA500's Avatar
Default Pulled these codes - to worry or not to worry?
Got a CEL yesterday, pulled these codes today with VAGCOM.
The only one that concerns me is the first, control valve.
The turbo seems to surge when i first get on the gas during normal acceleration. Is this normal? I mean I can hear it spool really hard and then let off and start spinning up normally as I slowly accelerate. Does this in pretty much every gear.
Does anybody experience this? Is this normal?
VAG-COM Version: Release 409.1-US
TIM
Control Module Part Number: 8N0 906 018 L
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 07500
Work Shop Code: WSC 12851
Additional Info: TRUTX28NX11015062 AUZ5Z0Y8222341
4 Faults Found:
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P1200 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-10 - - - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
Old Oct 3, 2007 | 01:16 PM
moeron7's Avatar
Default RE: Pulled these codes - to worry or not to worry?
Looks like your engine is about to die.
Old Oct 3, 2007 | 01:52 PM
NeXeA500's Avatar
What is that supposed to mean?
Old Oct 3, 2007 | 02:20 PM
NeXeA500's Avatar
Looks like your engine is about to die doesnt help me at all. Dont waste both of our time writing something that stupid.
Old Oct 3, 2007 | 02:39 PM
theTTkid's Avatar
by the turbo "surging" you mean it pulls you really hard early?
Old Oct 3, 2007 | 02:45 PM
techbod's Avatar
17608 - P1200 not on my database it starts with P1201
problem does sound like n75 valve (turbo waste gate valve ) and I agree the other codes are intermittent
Old Oct 3, 2007 | 02:51 PM
quattro411's Avatar
the cylinder misfires could be bad coil packs
Old Oct 3, 2007 | 03:41 PM
diehlryan's Avatar
n75 or DV not holding boost?
Old Oct 3, 2007 | 05:06 PM
moeron7's Avatar
Try new plugs, coil packs and a new DV. Shouldnt misfire after that. Then again, the BOV might be throwing the first code. Dont know for sure though.
Old Oct 3, 2007 | 05:42 PM
NeXeA500's Avatar
I think it may have been a cold start that gave me the misfire. The turbo doesnt necessarily pull hard because I am not on the throttle hard, it just spins up hard at first, then spins down and then keeps spinnig up regularly as I accelerate. It pretty strange.
Could a cold start be to blame for the codes? I cleared them and they havent come back on. I may just need to clean my plugs?
da604a
Dec 12, 2007 06:10 PM
dfrost
Sep 14, 2007 03:04 PM
qUaTtRoA4
Apr 21, 2007 11:34 AM
keko2004
Nov 6, 2006 01:15 PM
