showing no boost from gauge
hey guys i have just put my boost gauge in. when i started the car the vac read 20. im not sure if thats ok. so i took her for a test run to see if the gauge was showing any boost. i took are on a strip and booked it. the highest reading i got was 2lbs boost. and thats at 5500-6000rpm anything under was showing either 0lbs boost or 1 lbs boost. what could be the cause of this, or is this normal for my car. also, with de-acceleration that vac would read 25, and at a hault it would read 20, and with my ac on it would read 10 or 15. normal?
98 a4 1.8t QU
98 a4 1.8t QU
Read this: http://goapr.com/Audi/support/boost_gauge_pod.pdf
The best place to tap into is on the front of the intake manifold like it shows.
ORIGINAL: keko2004
thats the one i hooked up to. not the one nearest the back which i belive is for the fuel. i will take a pic if you want.
clamp all those connections (i used zip ties). that may be where you are losing your vac pressure. take a pic of the face of the boost gauge or tell us the brand name.
