Signs of bad ball joint?
Old May 26, 2005 | 10:33 PM
kingming's Avatar
Default RE: Signs of bad ball joint?
sounds like a ball joint, better off changing the whole control arm they are not bad just did mine
Old May 31, 2005 | 10:41 PM
A4NightRider's Avatar
thanks for the responses....appears to be my lower control arms...nearest the engine...sprayed with a lil WD40..and the squeak went away....not a big deal at all...will replace this weekend...
Old Jun 1, 2005 | 11:37 AM
Jupiter's Avatar
Apparently this is a known fault with Audi A4 1996+ Models.
The will do you a free check and I am told fix it for free if the mileage is less than 130 and has a FSH.
Give your local dealer a ring.
Old Jun 1, 2005 | 09:20 PM
FSH?
it has 91k on it.......i'll prolly end up fixing it myself...not to hard to replace them...30 bucks for the bushing at kragen...
Old Jun 1, 2005 | 09:48 PM
BFlan2001's Avatar
only the two front lowers are covered by the service action...i had 138k when i had mine done
Old Jun 7, 2005 | 09:49 AM
Jupiter's Avatar
ORIGINAL: A4NightRider
FSH?
FSH = Full Service History.
Old Dec 13, 2005 | 01:24 AM
ryanmcell's Avatar
sorry to bring this up from the dead, but i have a problem with the clunk and need my UPPER front L&R ball joints fixed so i can get an alignment.
is this covered under the service action or just the lowers?
wheres a cheap place for picking up these oem parts?
Old Dec 14, 2005 | 02:06 AM
  #18
Tonyd's Avatar
Just the lowers are covered. I purchased my complete set from getcoolparts.com, a site sponsor. They also sell them individually.
Old Dec 14, 2005 | 03:16 AM
  #19
AUDI1.8tT's Avatar
I just had my front right ball joint replaced this past weekend...i noticed a pretty annoying sounds, like something was dry or rubbing when turning the wheel at slow speeds...i also took off the wheel and found nothing wrong...i originally thought it eas either bad bushings or the control arm, then went and got it checked out and sure enough...ball joint...id say im about 95% positive thats what the problem is...same thing happened to me
AudiTurbo
Mar 21, 2012 01:47 PM
ShqeviTT00
Sep 15, 2010 12:41 PM
blazinhaze609
Mar 5, 2009 01:50 PM
mattr7786
Aug 18, 2007 05:14 PM
morrisonjd84
Dec 14, 2004 01:43 AM
