slotted VS stock
Old May 19, 2006 | 01:31 AM
16w/A4's Avatar
Default slotted VS stock
how much difference is there, i know slotted release gasses better but is there a difference for the 200 extra ill be spending?
Old May 19, 2006 | 01:32 AM
BadLuckAudi's Avatar
Default RE: slotted VS stock
not alot of difference unless your gunna be doin some autox
Old May 19, 2006 | 01:34 AM
miked's Avatar
^Yep not worth it with the little power you have right now. I say dont spend the 200 extra. Tint your windows or somethin (I see youre a 12v so there isnt tooo too much you can do.)
Old May 19, 2006 | 02:04 AM
16w/A4's Avatar
yeap, thanks dudes that what i needed, thinkin about sellin for 1.8 but im too attached, hopefully an S4 in the future
Old May 19, 2006 | 02:20 AM
miked's Avatar
good move. make it happen sometime down the line. you'll have fun either route you choose.
Old May 19, 2006 | 03:46 AM
Sp33d07's Avatar
but how good though when the stock ones hold enough for your abs to kick in. i would keep it stock unless if you have bigger wheels that have better grip and your car actually needs it
Old May 19, 2006 | 04:37 AM
kraylon's Avatar
i have slotted and cross drilled all the way around with ebc red stuff brakes and it stops a whole lot better but i did all these at the same time so i have no idea which is doing the job i also have 18' wheels so i get the co0lness factor i got mine from ecs tunning there weren't too bad on price
Old May 19, 2006 | 11:26 AM
north5995's Avatar
I have slotted x-drilled and they were like $20 more. If you have some nice wheels that can show them off, why not. I don't think you'll notice much difference unless you are tracking the car.
Old May 19, 2006 | 12:38 PM
Jestnomen's Avatar
6th Gear
I bought the slotted ones on my 12 valve when I had it. All it did was create twice the brake dust.
Old May 19, 2006 | 01:53 PM
north5995's Avatar
Yeah I'll agree with Jest. If you go slotted or x-drilled, you will probably want to run performance pads otherwise if you get a soft pads they will get chewed up quick. The performance pads cause more squeeling (as if your pads are low).
