Snake noise... HELP
Old Apr 24, 2007 | 05:01 PM
onepoint8tee's Avatar
Default RE: Snake noise... HELP
ORIGINAL: akoby9
thanks onepoint! I guess that would make sense, I thought it was maybe something that was coming apart/loose but I couldn't find anything, guess I'll order that forge007 now!!! and see if that fixes the problem.
ummmm and as for that snake... I HATE snakes soooo freaking bad, btw... that thing would have froze this morning here in steamboat seeing as it snowed!
Why would you order a new 007 when you can have my 006 for half the cost?? The only differences between them are size, and you use allen bolts to take it appart instead of unscrewing it like the 007. The 007 design was aimed more towards S4 applications where 2 DV's are used in a location where space is minimal. The 006 performs exactly the same and is only a little bit bigger.The 007 is notconsidered an upgrade to an 006, they are just a slightly different external design. Check out the link in my sig for more details. Plus, mine comes with extra parts for the next time it needs to be serviced.
Old Apr 24, 2007 | 05:39 PM
akoby9's Avatar
^DAHHH, totally would have been interested, except I already orderd a new one.... Thanks though
Old Apr 24, 2007 | 05:54 PM
A4speed's Avatar
I've had this problem, I think it might be a hose on the right side of the engine. I'll go take a pic.
Old Apr 24, 2007 | 05:58 PM
A4speed's Avatar
it will be a few min., batteries are recharging, but its by the turbo manifold, its 2 hoses that kind of clip together, see if its disconnected or loose. I'll have a pic up soon.
Old Apr 24, 2007 | 06:18 PM
A4speed's Avatar
The hose right above the manifold.
http://i60.photobucket.com/albums/h6...h/DSCF0014.jpg
Old Apr 24, 2007 | 06:57 PM
akoby9's Avatar
are you talking about the hose right above that orange one?
Old Apr 24, 2007 | 07:11 PM
A4speed's Avatar
yeah right above my lame red hose cover, correct
and then right above the brown one.
Old Apr 24, 2007 | 07:12 PM
  #18
A4speed's Avatar
that stopped clipping together on mine and all I heard was a hissing sound from it like it was sucking in air or something. It was crazy, but that was a problem I once had, took awhile to figure out that that was it, kinda annoying.
Old Apr 24, 2007 | 07:13 PM
  #19
techbod's Avatar
pictures
Old Apr 24, 2007 | 07:24 PM
  #20
Yeah that area is common for leaks on 00+ engines. Its a strange puzzleof vac lines. AEB engines (97-99.5) are far less complicated vaccum wise.
