snub install?
Old Dec 7, 2005 | 11:48 PM
juice88's Avatar
Default RE: snub install?
u have to remove the bumper, and all this other ****, how does that take only 15 minutes?
Old Dec 8, 2005 | 02:04 AM
eisman's Avatar
- Take the bolts off the shroud at the front of the engine where the snub goes.
- take nut off lower motor mounts.
- Jack up the engine enough to take the shroud off
- Replace the snub
- Lower engine
- Bolt up lower motor mounts
- Bolt up shroud
Done.
Make sure you find a good place to jack up the engine. Do NOT put the jack under the oil pan. I used a piece of wood to get up to the block for lifting.
Old Dec 8, 2005 | 02:06 AM
Karl's Avatar
its really easy to pull the bumper off..
you would shave the outside if it didnt fit.. try microwaving it for 30 seconds to help it on the pin.. once you get in there you will be like ohh ok
Old Dec 8, 2005 | 03:11 AM
apg96's Avatar
I know this is an amazing install but how can it be taht easy if the APR instructions are so long. Are u guys shortcutting it at all? Do u think im capable of doing this?
Old Dec 8, 2005 | 03:13 AM
Karl's Avatar
yeah. its seriously easy
Old Dec 8, 2005 | 03:22 AM
apg96's Avatar
then why is it have so much more on teh APR insturctions or are u following it and saying its easy?
Old Dec 8, 2005 | 03:25 AM
ExpLlclT's Avatar
is the greedspeed.com snub mount as good as the apr one ? because its 12 bucks compared to 50 and if its the same im going cheap
Old Dec 8, 2005 | 03:26 AM
  #18
Karl's Avatar
dude.. here are the instructions.
1. pull of bumper by removing two bolts.. remove screws on top of front support that is above headlights..
2. pull radiator out and up.. becareful as headlights will still be attached..
3. remove snub
4. put new snub on.
5. re assemble.. really freaking easy
Old Dec 8, 2005 | 03:32 AM
  #19
ExpLlclT's Avatar
www.greedspeed.com apr.com ,snub mounts, any diffrentce ?
Old Dec 8, 2005 | 03:33 AM
  #20
Karl's Avatar
yes... greedspeed is a little bit smaller.. i would recommend the other two
