snub install?
- Take the bolts off the shroud at the front of the engine where the snub goes.
- take nut off lower motor mounts.
- Jack up the engine enough to take the shroud off
- Replace the snub
- Lower engine
- Bolt up lower motor mounts
- Bolt up shroud
Done.
Make sure you find a good place to jack up the engine. Do NOT put the jack under the oil pan. I used a piece of wood to get up to the block for lifting.
- Replace the snub
- Lower engine
- Bolt up shroud
Done.
its really easy to pull the bumper off..
you would shave the outside if it didnt fit.. try microwaving it for 30 seconds to help it on the pin.. once you get in there you will be like ohh ok
dude.. here are the instructions.
1. pull of bumper by removing two bolts.. remove screws on top of front support that is above headlights..
2. pull radiator out and up.. becareful as headlights will still be attached..
3. remove snub
4. put new snub on.
5. re assemble.. really freaking easy
3. remove snub
4. put new snub on.
