snub mount
Old Mar 1, 2005 | 02:17 AM
K69camaroz28@aol.com's Avatar
Default snub mount
I did a search for snub mount before i posted.... When should it be replaced after how many years ( or just when the timing belt needs replacing) ? Also would this be conciterd an upgrade?? Do the ones from apr..etc... provide smoother shifts than the stock ones? Lastly how much of a pain in the *** is this to do (what needs to be done)? Thanks a lot!!!!! [sm=thanx.gif][sm=smiley20.gif][sm=smiley21.gif][sm=shades.gif]
Old Mar 1, 2005 | 03:17 AM
Transverse's Avatar
Default RE: snub mount
well..you pretty much have to take off the front bumper and all that that entails..that's why its a good idea when you get your belt done cuz its right there. If you feel a little jolt when you shift then it would be a good idea to replace the snub mount..it will definitly make the shifts smoother. They can be a p.i.t.a. to get on..a few seconds in the microwave and some lube should do the trick though(little advice brrman gave me..but I haven't tried it out yet).
-T
Old Mar 1, 2005 | 08:01 PM
hb972.8q's Avatar
i got one from greedspeed ...lot cheeper but same item. you can look here on how to install
Old Mar 1, 2005 | 08:16 PM
BFlan's Avatar
wow, why is that greedspeed snub mount so much cheaper?? it also looks different in the picture from the apr one, are they really the same?
Old Mar 1, 2005 | 08:18 PM
Jestnomen's Avatar
6th Gear
I bought mine from Abnormally aspirated.
I used some white lithium to make it slide on easier:
Old Mar 1, 2005 | 08:28 PM
BFlan's Avatar
which snub mount did you use jest?
Old Mar 1, 2005 | 08:29 PM
Jestnomen's Avatar
6th Gear
did you read my post? Abnormally Aspirated
Old Mar 1, 2005 | 08:46 PM
BFlan's Avatar
OMG i must be high, my bad jest
Old Mar 1, 2005 | 08:47 PM
Jestnomen's Avatar
6th Gear
haha, I do the same thing all the time.
Old Mar 1, 2005 | 08:58 PM
BFlan's Avatar
is it me or does abnormally aspirated really not have a website? i googled it and came up with garbage, am i still high? 0 results on ebay too
