snub mount install cost
Old Aug 6, 2005 | 08:56 PM
germancarmaniac's Avatar
Default snub mount install cost
Everyone says the snub mount is a good upgrade but how much does it cost? What all is involved, and is it that hard?
Old Aug 6, 2005 | 09:36 PM
brrman's Avatar
Default RE: snub mount install cost
about 2-3 hours if you do it yourself, depending on your knowledge of the front end.
Must be put in the service position (front released and pulled forwards slightly).
It's not that hard. I've done it twice.
Old Aug 6, 2005 | 10:02 PM
Jestnomen's Avatar
6th Gear
It also depends on whether you have a B5 or B6/B7. The B6/B7 doesn't need to be put into the service position and takes only like a half hour - hour.
Old Aug 6, 2005 | 11:02 PM
david9999's Avatar
If you are doing your timing belt soon, I'd do it at the same time and once you have the front of the car removed, putting in the snub mount only takes a few minutes.
If you have a tiptronic, I would not get the APR mount. The vibration is bad.
Old Aug 6, 2005 | 11:28 PM
Beaner's Avatar
alright, whats a Snub mount?" please educate me
Old Aug 6, 2005 | 11:59 PM
Dave666's Avatar
Brrman or anyone for that matter with tip and a snub..
Is there a noticable difference in shifting ?
Old Aug 7, 2005 | 12:05 AM
p2ii's Avatar
ORIGINAL: Beaner
I second that!
Old Aug 7, 2005 | 12:06 AM
tontod's Avatar
Doh, I have a tiptronic and I thought getting the snub mount would be a good idea. Should I return it, David999?
PandaXpress's Avatar
no it will help
Old Aug 7, 2005 | 02:13 AM
rjplunk9's Avatar
ORIGINAL: Beaner
read this link and it will inform you!
https://www.audiforums.com/m_99845/tm.htm
