snub mount install problem
Old Nov 17, 2006 | 05:36 PM
EliteTuning1's Avatar
Default snub mount install problem
ok so i got the bumper off and im taking off the radiator support bolts and i go to take off the bumper shocks bolts and they are all stripped,,,, i could only get 2 out. someone please help me so i can get this on. i dont know wut to do.
Default RE: snub mount install problem
01 a4 1.8t
Old Nov 17, 2006 | 06:16 PM
onepoint8tee's Avatar
Bumper shocks deffinately have to come off to get the snub on. You saying the torx bolts are stripped on the head or the threads???
Old Nov 17, 2006 | 07:02 PM
they are stripped on the heads.
Old Nov 17, 2006 | 07:16 PM
acetrebo's Avatar
That sucks.
First, get some new bolts to replace these, probably dealer part.
To get them out, unless someone had a better suggestion:
Take a thin grinding wheel on a dremel or drill, and make a groove in the bolt so you can try to use a Large /heavy duty flathead screwdirver to get it out.
Obviously your gonna need a littlt torque to get it out, so maybe use a screwdriver bit in a socket wrench to do the dirty work.
Old Nov 17, 2006 | 07:25 PM
Ford2Audi6's Avatar
if you have a welder, you can tac weld a spare socket on and use a breaker bar to turn it out.
Old Nov 17, 2006 | 07:33 PM
ORIGINAL: acetrebo
That'll work, great suggestion!
Old Nov 17, 2006 | 09:38 PM
wood_e's Avatar
How on earth did they get stripped? Were you using the CORRECT torx bit? My 96's were just fine getting out with the proper bit.
Old Nov 18, 2006 | 01:24 PM
Transverse's Avatar
I'll bet someone else had been in there before...leave it to the pro's to strip your bolts!...
-T
CCA4
Jan 18, 2011 07:12 AM
horsecrazy8907
Apr 5, 2009 06:25 PM
bpwS4
Nov 2, 2006 12:47 AM
audihere
Jun 20, 2006 02:52 AM
germancarmaniac
Aug 7, 2005 03:37 PM
