So i found out how to run unlimited boost...
Old Dec 18, 2007 | 10:02 PM
chaos92287's Avatar
Default So i found out how to run unlimited boost...
...but i fvcked up my car. I was installing my boost controller and realized half way through i need some clamps and connectors fron the auto parts store. I reassembled everything and hooked the n75 back up wrong. i put the nipple that goes into the TIP to the banjo screw on the turbo compressor and when i was out on the road i stepped on it and my boost gauge went beyong 25 psi (the max it reads) and it was a hell of a lot faster, but then the car made this loud pop and started to die. i pulled it over into a parking lot and hooked the n75 up the right way and tried starting the car again, but still nothing...then i realized the hose coming off the throttle body popped right off. i reconnected it and tried starting it again but it wouldn't turn over. while i was trying to start it after fixing the n75 but the tb hose still disconnected, it smelled a lot like fuel, are my cylinders fuel soaked? is that why its not starting? if so how do i fix this?
Old Dec 18, 2007 | 10:07 PM
Jeff's Avatar
Zombie Defense Force
Default RE: So i found out how to run unlimited boost...
so you over boosted your car? and now it wont start? that dosent sound good. can you check compression?
Old Dec 18, 2007 | 10:18 PM
Bogie's Avatar
sorry to hear that dude. can't help you much now, but I'll talkt to some of the guys i work w/ that run BTs and see what they think it is. Do you think you blew the head gasket or had it cranked up so hard it broke the timing belt? good luck.
Old Dec 18, 2007 | 10:19 PM
Rhinop21's Avatar
Wouldn't have expected that from a member with 5000+ posts....
Old Dec 18, 2007 | 10:24 PM
chaos92287's Avatar
ORIGINAL: Jeff
no but i can go get a gauge tomorrow and check it
ORIGINAL: Bogie
i dont think anything got fvcked up, i just blew the hose off the tb and tried starting it and it wouldn't turn over and then i smelled fuel, which lead me to believe it was not getting air, so i looked around some more and found the hose blown off the tb. i reconnected it but it still wouldn't start...
ORIGINAL: Rhinop21
1- post count doesn't refect intelligence
2- i installed it wrong cause i looked up a daigram and it was labeled wrong. i was in a hurry so i slipped up on one detail
Old Dec 18, 2007 | 10:31 PM
Rhinop21's Avatar
I beg to differ once the post count gets above 1000.
Old Dec 18, 2007 | 10:36 PM
Karl's Avatar
clear any codes and see if she fires up after testing compression
Old Dec 18, 2007 | 10:37 PM
aRIf's Avatar
Hope only the spark plugs soaked with fuel. I remember when I had leak on my ic, it gets soaked crazy fast and does not let car run.
did u have time to look at the plugs yet?
did u get cel or anything?
man sorry to hear that.
Old Dec 18, 2007 | 10:38 PM
chaos92287's Avatar
ORIGINAL: Rhinop21
actually i know a couple of post ****** in the off-topic section that dont know that much about their car and have over 1000 posts, but thats beside the point. why the fvck are you even posting in my thread if you aren't contributing anything? call me an idiot i dont give a ****
Old Dec 18, 2007 | 10:47 PM
chaos92287's Avatar
i had it towed to my house and now im at my friends house (where my tools are) so im just gona go over to my house in like 30 min and clean the spark plugs. hopefully it'll fire
