So i found out how to run unlimited boost...
Old Dec 19, 2007 | 12:48 PM
  #21
Bogie's Avatar
Default RE: So i found out how to run unlimited boost...
If you wanna try that, then just get the cheaper BKR6E or BKR7Eplugs to see if the plugs are the reason.
I'd try spraying off thefuel soaked plugswith partscleaner and then let themdry.Are the plugsgettingfuel soaked again(after you cleaned and dryed them)when you just tried to start it? Can you smell gas at least? If not maybe the car/ecu has some sort offuel shut-offsystem to protect the engine and it needs to be reset somehow.
Old Dec 19, 2007 | 01:04 PM
  #22
bob12312357's Avatar
ORIGINAL: AudiCross
damn good louck man. i bet those few seconds with loads o boost were the best uv had in that seat ;-)
I dont think he could have blown a head gasket. people have boosted the crap out of GT series turbo's and not blown that. i think you are probably right about the fuel. hopefully nothing really oroke in the process
Not a good practice 2 do that as the turbo is runnin terribly outta efficency and ur gonna fry it sooner rather then later.
Old Dec 19, 2007 | 01:07 PM
  #23
MrFlippant's Avatar
ORIGINAL: chaos92287
ORIGINAL: Rhinop21
I beg to differ once the post count gets above 1000.
actually i know a couple of post ****** in the off-topic section that dont know that much about their car and have over 1000 posts, but thats beside the point. why the fvck are you even posting in my thread if you aren't contributing anything? call me an idiot i dont give a ****
Me, for example. All I know is gas goes in, fire happens, exhaust comes out, and my wheels spin. But I've got over a thousand posts!
Anyway, that sucks *****, Chaos! Hope you get it figured out...
Old Dec 19, 2007 | 01:14 PM
  #24
chaos92287's Avatar
ok im gonna try disconnecting the battery. i did a TBA, but didn't disconnect the battery. maybe the ecu has some weird safety feature. and i'll spray the injectors down with parts cleaner and dry them out and see what happens
Old Dec 19, 2007 | 01:59 PM
  #25
dmrdennie's Avatar
This happened to me years ago. My wastegate stuck closed and I overboosted. I heard a "pop" also. On that car, there was a safety built in to kill the fuel pump relay. After this was reset, it started and ran. The bad thing was, the turbo did fail about three weeks later. Hope this helps.
Old Dec 19, 2007 | 03:26 PM
  #26
Bogie's Avatar
Chaos, you're spraying the spark plugs, right, not the injectors. Parts cleaner will probably damage the injector O-rings.
As for the fuel pump cut-off, I have no idea where they are on our cars.
I had an 89 mustang gt (not mine) roll down my driveway and hit some trees. It wouldn't start afterward, and we found that there was a button/switch in the hatch area that had to be pushed to reset the fuel pump cut-off. Again, this was for a collision, which prob doesn't apply to your circumstances. Although I could imagine the ECU shutting off spark and/or fuel if there was a big fvcking problem with the big numbers your MAF was reading prior to the hoses popping off from too much boost pressure/not enough clampdown.
Your car is at leastpre-MAP sensor, so at least that is one less thing that you don't have to look into. Hope it's just the plugs. Good Luck with that.
Old Dec 19, 2007 | 04:35 PM
  #27
A4speed's Avatar
that sucks man, sounds like u almost got it though.
damn, i have over a 1000 posts and I'm learning crap all the time... [:@]
Old Dec 19, 2007 | 05:08 PM
  #28
1.8TK3MP's Avatar
check your stock DV to make sure you didnt blow it to were it broke or blew off...which could cause a nice vac leak
Old Dec 19, 2007 | 05:17 PM
  #29
Bogie's Avatar
ORIGINAL: 1.8TK3MP
He's got a Forge 004 you dumbass.
Old Dec 19, 2007 | 05:23 PM
  #30
dafowler88's Avatar
Yea man, I would just replace them and see if that works, if it doesn't. Just take'em back..
