some code help
Old Mar 22, 2006 | 01:15 AM
mjvss21's Avatar
Default some code help
VAG-COM Version: Release 512.1-UD
Control Module Part Number: 4B0 906 018 P
Component and/or Version: 1.8L R4/5VT G 0005
Software Coding: 07201
Work Shop Code: WSC 06335
3 Faults Found:
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
16806 - Main Catalyst; Bank 1: Efficiency Below Threshold
P0422 - 35-00 - -
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
already cleaned the MAF and it didnt do the trick
this is for a 2000 1.8T QM
Old Mar 22, 2006 | 01:17 AM
xx18quattroxx's Avatar
Default RE: some code help
what did you clean the maf with? any chemicals will destroy it
Old Mar 22, 2006 | 02:00 AM
mjvss21's Avatar
carb cleaner, thats not good the middle code i have never got before
Old Mar 22, 2006 | 08:29 PM
hoonee46's Avatar
cleaning the MAF with carb cleaner does not destroy the sensor as long as you do it correctly (or so I thought... my car is fine)...
from the codes you're throwing, If I were you, I would start with the basics if not done already - air filter, spark plugs, clean out EGR, lubricate IAC, put some seafoam in your fuel, with your oil, and feed it through vac lines into crank case, etc... you can find how to's on the forums... While this probably won't fix all your problems, easy fixes is the first thing to try... plus, cars are not like girls... if you treat a car with care and respect, it will do the same for you.
If in doubt, I had a few readings on my 96 2.8... cylinder 4 misfire, EGR, IAC valve, and something with MAF, i forget....
I cleaned out the MAF with carb cleaner, Lubed up the IAC with wd40, plugs+wires, seafoam..... checked up all my vacuum lines.......
got rid of EVERYTHING! Only spent $100 on all chemicals, tools, etc.... got to spend time on the car (which i love doing) car had smooth idle, no CEL.... this would be the best case scenario, but it might help you still.. good luck
Old Mar 23, 2006 | 12:22 AM
mjvss21's Avatar
well i have been cautious about using sea foam because it seems like every time it is discussed people are split on it. some people say it works wonders and some say it gets ride of all the gunk that the cylinders build up, but they say that is bad for it becasue it is so used to it... that probably mad no sense but i know some of you know what i aam talking about
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
snowman_w900
Apr 14, 2010 12:30 AM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
tonym
Jun 14, 2006 03:49 AM
