Spark Plugs- - -
I got a couple options wood_e.
NGK Spark Plugs (#PFR7B) 1 Heat Range Colder than Stock OEM - set of 4 plugs ES#868
Spec'd by APR for APR 1.8T Stage 3 (transverse and longitudinal) learn more
$57.92
NGK Spark Plugs (#BKR7E)-Priced Each ES#4408
Copper cored plug - as talked about on the forums @ vwvortex.com learn more
$2.25
OEM NGK Spark Plugs (#PFR6Q) - set of 4 plugs ES#592
- Passat/A4 engine codes AUG, AWM, ATW learn more
$57.96
OEM NGK? ? ? ? ?
Blah I gotz to get my Oil change also.
5w40 or 0w40 or 10w40 (FULL SYTHETIC or HALF) - -I alrdy bought my Bigger Oil filter
I see some guys running Half & Full (when I did search)
Mods Below
Air Box Mod (k&N Filter)
APR SNUB
Fuel-Pressure Gauge
Boost Gauge
ECS Drilled/Slotted Rotors (painted calipers /audi decals)
15%tints
1-Piece HALOS
Independent Fog Light mod
Rs4 Fogs
Debadged of course
$57.92
$2.25
$57.96
OEM NGK? ? ? ? ?
Mods Below
APR SNUB
Fuel-Pressure Gauge
Boost Gauge
15%tints
1-Piece HALOS
Rs4 Fogs
Debadged of course
ORIGINAL: wood_e
If you had a V6 I'd say go with OEM bosch plugs but since you have a 1.8 go with NGKs.
Dont see that MODEL on ECS????
http://www.ecstuning.com/stage/edpd/...ategory=Engine
ORIGINAL: onepoint8tee
Come on spiel... Try a search... BKR6E is what you want for stock/chipped. BKR7E for K04 or more.
ORIGINAL: Dj Spiel
Why would you want to pay shipping costs for spark plugs when you can get them localy?
True dat. Thanks Tree.... to lazzy to search
Oh and on OIL any reccomends??? Alot of 1.8T are running diff things
Ow40 then 5w40 should be aight correct? i dont think they have ow40 over here.... ive see n5w40
