Spark plugs
Old Sep 17, 2007 | 09:58 AM
keko2004's Avatar
Default Spark plugs
hey, i noticed that my spark plugs are burned up. what kind of spark plugs does my car call for? 98 1.8t a4. i did a search on this forum but couldnt find anyone talking about my cars year with the 1.8t motor. anny help would be appreciated. thanks.
Old Sep 17, 2007 | 10:01 AM
onepoint8tee's Avatar
Default RE: Spark plugs
ORIGINAL: keko2004
Rofl The AEB engine (97-99.5) is the very most talked about engine on this forum. Did you REALLY try to search, or are you just foolin?
Elaborate on burned up please.
EDIT
Ok ok I did a search on 1998 spark plugs and didnt come up with much either. NGK BKR6E for stock, or NGK BKR7E if youre running near 20 psi with a chip or more. Those plugs can/should be used in all the years for the 1.8t engine
Gapped to .030 for stock, and .028 for chip+
But when you say burned up, even 1 week old plugs arent going to look pretty. A little carboned, but if you dont know when theyve been replaced last its probably a good idea to do them.
Old Sep 17, 2007 | 10:11 AM
kextyn's Avatar
click here
Old Sep 17, 2007 | 10:14 AM
See edit
Old Sep 17, 2007 | 10:34 AM
keko2004's Avatar
ty. there wasnt much search results on the sparks for my motor was there? the only reason im doing this is cause im missfireing on cyl. 3. and im trying to see if its my coils or my sparks. i swapped coil 3 with coil 2 to see if im gonna missfire on cyl. 2. if it fires on cyl. 3 again im gonna swap cyl3 spark with cyl 2 spark, and see if i still get a misfire on cyl 3. if it still missfires on 3, then i will return to you guys for some help. appreciate the help onepoint8. ty
Old Sep 17, 2007 | 10:40 AM
If youre going to go to the trouble of swapping spark plugs, just replace themall. Those NGK's I was talking about are about $1.70 per plug. But your problem is probably a coil pack or your ICM.
Old Sep 17, 2007 | 12:47 PM
keko2004's Avatar
i changed my icm about 8 months ago. can it go bad that quick? also, i cleared the codes last night, and this morning i noticed a little hesitation in my car but there no check light on. i went home n scanned it again. same code came up p0303, thats with the coil swap. so im gonna go replace all my sparks right now n let u know how things go. i guess if it still happens its my icm
Old Sep 17, 2007 | 02:39 PM
keko2004's Avatar
went to audi/vw mechanic and picked up brand f***ing new sparks. drove ood a for a bit, boom misfire cyl 3. this is so damn annoying right now. so its not my coils and not my sparks. ICM? is there a way to test to see if its the icm? i dont wanna spend more money if thats not the problem.
Old Sep 17, 2007 | 02:53 PM
ORIGINAL: keko2004
http://forums.audiworld.com/a4/msgs/1594531.phtml
Old Sep 18, 2007 | 10:37 AM
keko2004's Avatar
i tried using doing wha they did , but i am getting no reading from any of them on my icm. maybe im doing it wrong. not sure i did exactly wha they said to do excapt my multimeter is different from theres. maybe thats why. also when i took off my icm i noticed this yellow build up on the bottom of the icm. is that ok?
cwedholm1
Mar 13, 2010 11:47 PM
Eric_C
Dec 13, 2009 10:48 PM
hsbertiii
Jan 19, 2008 01:42 PM
domino877
Nov 28, 2007 09:09 PM
aerostatwv
Nov 22, 2007 07:20 PM
