Spark plugs?
Old Dec 5, 2007 | 11:57 PM
balkranjit's Avatar
Default Spark plugs?
hey guys, i changed my plugs about every 10-12 000 km using NGK BKR6E gapped to .28, last two times i changed i noticed one is always a little different. I have some pics of them wondering if one of my coilpacks might be done or on its way out. Reason why i think that is i never hit 18PSI anymore. i usually spike 15 hold 13 when i am by myself. And if i have a few people in the car and under heavy acceleration the boost gauge flutters back and fourth from 10 to 13 psi pretty quick and never goes higher than that. I have checked for boost leaks and there is none, i changed my fuel pressure vac and intake vac going to DV. Any ideas anyone?
Boost guage reads 18 vac at idle.
Here are the links to the spark plugs pics the one in question is spark plug 4. thanks for everyones input.
http://www.fileden.com/files/2007/10.../Spark%201.JPG
http://www.fileden.com/files/2007/10.../Spark%202.JPG
http://www.fileden.com/files/2007/10.../Spark%203.JPG
http://www.fileden.com/files/2007/10.../Spark%204.JPG
http://www.fileden.com/files/2007/10...20Shot%202.JPG
http://www.fileden.com/files/2007/10...oup%20Shot.JPG
98 a4 1.8t , chipped and exhaust.
Old Dec 6, 2007 | 12:04 AM
hiwords's Avatar
Default RE: Spark plugs?
looks like there's alot of oil on it.
Old Dec 6, 2007 | 12:33 AM
Bogie's Avatar
Did that one smell rich, like fuel? try switching coil pack from a good cylinder to the one that plug was in and see if the problem follows the coil pack or stays in that cylinder. If it follows the coilpack, the coilpack is probably bad. If the problem stays in that cylinder with a known good coilpack, it could be the wiring to the coilpack for that cylinder or something else.
Old Dec 6, 2007 | 10:58 PM
balkranjit's Avatar
next time i change the plugs ill keep track of these small things, usually i have been to busy i honestly don't even know which cylinder it is. and ill try the coil pack change. thanks for the help guys. if anyone else has any thoughts let me know.
Old Dec 7, 2007 | 01:18 AM
domino877's Avatar
I just ordered pulstar plugs cost me 100$ there suppose to be the most powerful plugs ever made I think they have a built in transistor. When they come in I will install them and let everyone know how they work.
Old Dec 7, 2007 | 01:25 AM
Bogie's Avatar
hope they add 30hp!!!
cwedholm1
Mar 13, 2010 11:47 PM
Eric_C
Dec 13, 2009 10:48 PM
hsbertiii
Jan 19, 2008 01:42 PM
domino877
Nov 28, 2007 09:09 PM
aerostatwv
Nov 22, 2007 07:20 PM
