spark plugs keep vibrating loose
Old Mar 27, 2005 | 03:47 PM
macky2114's Avatar
Default spark plugs keep vibrating loose
Would there be any reason that one of my spark plugs on a 2.8 would be coming loose from vibration. it did it with the orginal set that was on the car when i bought it and now its doining it wit the new ones i just put on
Old Mar 27, 2005 | 05:29 PM
CRAZYHAWK's Avatar
Default RE: spark plugs keep vibrating loose
Are you losing compression in that cylinder?
Are you using spark plugs with washers?
Are you properly torquing them?
Old Mar 27, 2005 | 05:30 PM
david9999's Avatar
Are you torquing them correctly?
Are they supposed to use the gasket?
Old Mar 28, 2005 | 02:10 AM
macky2114's Avatar
i know i been torquing them right. see i don't know if they need washer i bought it used so it could orginaly had it and the last owner just never put them on but i don't know ?????????????????????
Old Mar 28, 2005 | 03:12 AM
trailboss's Avatar
You buy the car used or plugs used, if you bought the plugs used that would be the most retarded thing i've heard in a while. The plugs should have a washer that cant be removed, at least all the plugs i've instaled were like that.
norcal89451
Feb 24, 2013 10:56 AM
itsmatt33
Sep 18, 2009 01:13 PM
gedas429
Aug 10, 2009 01:15 PM
mattr7786
Aug 13, 2007 01:16 AM
