Speedometer "steps" to 160mph
Old May 27, 2007 | 02:17 PM
akawonderchild's Avatar
Default Speedometer "steps" to 160mph
On my1998 Audi A4 when you turn the ignition on oropen the door orturn on parking lights/headlights or press the clock adjusment/insturment illumination button the needle of the speedometer will quiver for about 7 secondsat 0mph and thenjump to 3mph, also the tachometer will not work until it also times out in about 7 seconds. Once in gear and moving the speedometer then jumps in increments of 4 or 5mph as long as your speed is increasing speedometer continues to jump to 160+mph, it will stay there until ignition is turned off then it "steps" back to 0mph. Once running the tachometer always seems accurate, I checked the vehicle speed sensor and it checked out OK. Used magnet andohmeter to check it. I checked grounds etc. they seem Ok.
[ul][*](ONLY DRIVER DOOR OPENING EFFECTS THE SPEEDOMETER)[*](WHEN OFF, SPEEDOMETER ALWAYS STAYS AT 3MPH)[/ul]
Old May 27, 2007 | 02:20 PM
techbod's Avatar
Default RE: Speedometer "steps" to 160mph
probably a shorted wire on the drivers door
Old May 28, 2007 | 10:36 AM
18T's Avatar
18T
lol i see this on early 90's models.
Old May 28, 2007 | 10:03 PM
ORIGINAL: 18T
Do you know how to fix it?
Old May 28, 2007 | 10:26 PM
18T's Avatar
18T
ORIGINAL: akawonderchild
ORIGINAL: 18T
sadly im not a tech so i dont know a fix off top of my head. BUT i could ask when i get to work tomorrow.
Old May 28, 2007 | 10:48 PM
ORIGINAL: 18T
ORIGINAL: 18T
Hey if you could it would be great, this problem has stumped my Dad and I for weeks now.
Old Jun 8, 2007 | 04:20 PM
On my1998 Audi A4 when you turn the ignition on oropen the door orturn on parking lights/headlights or press the clock adjusment/insturment illumination button the needle of the speedometer will quiver for about 7 secondsat 0mph and thenjump to 3mph, also the tachometer will not work until it also times out in about 7 seconds. Once in gear and moving the speedometer then jumps in increments of 4 or 5mph as long as your speed is increasing speedometer continues to jump to 160+mph, it will stay there until ignition is turned off then it "steps" back to 0mph. Once running the tachometer always seems accurate, I checked the vehicle speed sensor and it checked out OK. Used magnet andohmeter to check it. I checked grounds etc. they seem Ok. [ul][*](ONLY DRIVER DOOR OPENING EFFECTS THE SPEEDOMETER)[*](WHEN OFF, SPEEDOMETER ALWAYS STAYS AT 3MPH)[/ul]
Help me please!!
larrypzlast
Mar 10, 2009 08:27 PM
GatoRex
Mar 4, 2009 10:16 AM
Silverback4
Dealerships
Nov 27, 2008 09:22 AM
Gutterpelican
Jul 30, 2006 12:03 AM
Doose
Aug 24, 2004 02:02 AM
