starting problems
Hi
I am having trouble starting the car lately (2001 A4),whenI turn the key the whole way nothing happens.all the lights light up but the engine will not fire,the starter will not turn. it onlyhappens sometimes, maybe once a day, and then the car starts fine after that. It doesn't matter if the car is hot or cold. Doyou think it could be something to do with theimmobilizer? I don't thinkmyslef it is the battery as alarm and everything else still works fine.
Any advice would be greatly appreciated.
just opened up steering column at the end of the ignition there is a cluster of wires attatched to a black plastic connector is this the barrel,if so mine has no cracks no signs of wear,or is the barrell in side the ignition housing
Smokin Tubes
Feb 5, 2012 10:11 AM
so it must be the ignition if its not an auto
