starting problems
Old Apr 29, 2007 | 05:19 PM
irishaudi's Avatar
Default starting problems
Hi
I am having trouble starting the car lately (2001 A4),whenI turn the key the whole way nothing happens.all the lights light up but the engine will not fire,the starter will not turn. it onlyhappens sometimes, maybe once a day, and then the car starts fine after that. It doesn't matter if the car is hot or cold. Doyou think it could be something to do with theimmobilizer? I don't thinkmyslef it is the battery as alarm and everything else still works fine.
Any advice would be greatly appreciated.
Old Apr 29, 2007 | 05:24 PM
wood_e's Avatar
Default RE: starting problems
ignition switch maybe? how many miles?
Old Apr 29, 2007 | 05:25 PM
techbod's Avatar
could be worn ignition barrel ( black box on the rear of the ignition ) plastic and wares out
Old Apr 29, 2007 | 05:27 PM
techbod's Avatar
also you dont say if its auto or manual? if auto it could be the inhibitor which wont let you start it in gear for safety reasons
Old Apr 29, 2007 | 05:29 PM
irishaudi's Avatar
its a manual with 75k
Old Apr 29, 2007 | 05:34 PM
techbod's Avatar
I was typing the same as wood_e at the same timeso it must be the ignition if its not an auto
Old Apr 29, 2007 | 05:44 PM
irishaudi's Avatar
if i replace the barrel will it effect the immobilizer-(if i have one) is it a hard job to replace,cost etc.
Old Apr 29, 2007 | 05:51 PM
auditech79's Avatar
Your 01 doesn't have immobilizer so its easy
Old Apr 29, 2007 | 06:00 PM
irishaudi's Avatar
just opened up steering column at the end of the ignition there is a cluster of wires attatched to a black plastic connector is this the barrel,if so mine has no cracks no signs of wear,or is the barrell in side the ignition housing
Smokin Tubes
Feb 5, 2012 10:11 AM
joe4123
Sep 16, 2009 11:17 PM
joe4123
Jun 19, 2009 08:05 PM
james0013
Sep 2, 2008 11:22 AM
Limmy711
Sep 15, 2005 02:11 AM
