startup problem
Old Jan 16, 2007 | 11:06 PM
xel04's Avatar
Default startup problem
Hey,
As of late, I noticed that when the car is full warmed up and in cold weather after leaving for a second, it has great difficult starting up. It eventually starts up but struggles for a second or two. Any ideas of what the problem can be?
Old Jan 16, 2007 | 11:14 PM
onepoint8tee's Avatar
Default RE: startup problem
First get the ecu scanned for fault codes. If there are none, try replacing your engine coolant temp sensor ($6 part easy to do).Also replace your spark plugs if you dont know if/when theyve been replaced. Those are the cheapest ways to start troubleshooting if there are no fault codes andif nothing else is obvious.
It helps if you mention your engine/yr when asking technical questions.
Old Jan 17, 2007 | 12:13 AM
xel04's Avatar
It is a 2003 A4 1.8T, and as far as I know the dealer said the sparkplugs were replaced at 40k, now im at 57k
thanks for the help
Anton653
B7 Models
Feb 26, 2011 08:50 PM
johnnyg
Nov 10, 2009 04:47 PM
oettinger1919
Dec 12, 2007 05:54 PM
02A418T
Apr 6, 2007 07:50 AM
onebelo
Aug 17, 2006 02:31 PM
