Steering Problem
Old Sep 20, 2007 | 02:02 PM
jrock's Avatar
Default Steering Problem
So I posted this a while back and got no answers. Unforutnately the problem got worst. It used to be when I only turned right that my steering would make a noise. Now when I turn it boths ways it makes the sound and it is alsoa lot louder. I can't figure out what it is. It is a loud creaking sound that kinda sounds like pieces are rubbing together. Could it just need some lube some where? Or do I have to replace anything? Is it a control arm or something with the steering? I need to get this fixed asap. It sounds like something might snap or break soon. Any suggestions would help. Thanks
Old Sep 20, 2007 | 02:04 PM
akielb's Avatar
Default RE: Steering Problem
Check out your TRE's - Tie Rod Ends - that what my "steering wheel noise" was
Old Sep 20, 2007 | 02:06 PM
jrock's Avatar
How hard are they to replace? Is there anything else you think it could be?
Old Sep 20, 2007 | 02:09 PM
jrock's Avatar
Did you steering creak when you turned it both ways?
Old Sep 20, 2007 | 02:19 PM
A4speed's Avatar
does it get hard to turn the wheel as it makes that sound, if so you could be running low on power steering fluid.
Old Sep 20, 2007 | 02:25 PM
jrock's Avatar
It is kind of harder to steer it. How do I flush the old power steering to refill it with some good new stuff?
Old Sep 20, 2007 | 02:28 PM
A4speed's Avatar
you don't need to flush out the old stuff, go to the audi dealership or a euro shop and buy the audi powersteering fluid. DO NOT BUY a generic brand, audi power steering fluid is different and the other fluids will destroy the power steering pump. once you buy it, just put some in and you should be good to go.
Old Sep 20, 2007 | 02:32 PM
akielb's Avatar
Use this DIY (http://www.audiworld.com/tech/wheel29.shtml) to figure out the location of the TRE's and then check the rubber boot on the top of them to see if they are broken loose at all. if you find that they are broken, spray some WD40 in there and if the noise stops that was your problem. I had noticed that mine was cracked a while before they started makeing this god awful sound when I turned the steering wheel - you can also have someone stand out in front of your car and listen while you turn the wheel
Old Sep 20, 2007 | 02:42 PM
jrock's Avatar
K thanks guys. I will check up on these and figure it all out. Thanks for the advice.
gold2734
Sep 3, 2009 08:58 PM
Lastb0isct
Feb 17, 2009 03:15 PM
99'A6
Sep 26, 2008 08:35 AM
B5nightrider
Oct 3, 2005 03:34 PM
mitao2000
Feb 8, 2005 02:41 PM
