Stero Question
Old May 26, 2005 | 08:40 PM
Jestnomen's Avatar
6th Gear
Default RE: Stero Question
You don't need any of that. You can tap into the Bose amp to add a subwoofer. I did it on my B5.
Here is the pinout diagram on the bose amp plug.
You'll notice Audi used a common ground preamp signal. So when you splice in the RCA's to go to your new amp you have to do something a little different. You have to combine the two grounds on the wires into one and splice it into the common line level ground.
There is also the switched amp turn on signal available. All you have to do is run a power wire from the battery through the ECU box to the trunk.
Old May 26, 2005 | 08:57 PM
CRAZYHAWK's Avatar
You'll need keys to remove the head unit. EBAY
Old May 27, 2005 | 05:06 AM
sandman's Avatar
remove the stereo look at the back, if theres an area with two rca cable outputs all you have to do is connect this to youre amp with cables. you will need to bua a wiring kit because you will need to ground youre amp and run a power supply directly off youre batterie with an inline fuse. you will also need to connect a remote wire off your amp to tell it when to come on and turn off, this is usually a blue wire(the wires should be labeled). this black box they speak of is pertty much a ghetto way of doing it, what it does is steal the power from the stock speaker wiring, if you go this direction sound quality wont be as good, which will be pointless because you own an audi.
Old May 27, 2005 | 10:27 AM
Jestnomen's Avatar
6th Gear
As far as I know there are no RCA preouts on the back of any Audi radio Sandman.
Old May 27, 2005 | 03:37 PM
hb972.8q's Avatar
i just took my car to a local sound shop. i have a cap and amp for my subs and a 4 ch amp for my rear deck speakers (aftermarket)( bostons) and stock fronts. too much of a pain to do it my self. all this is still running off my stock delta deck.
thunderrick
Mar 19, 2009 07:37 PM
01afour
Oct 19, 2008 07:09 PM
mwgordon
Feb 3, 2007 10:17 PM
LMAudi08
Sep 4, 2006 11:26 PM
foxys90
Jun 12, 2006 07:12 PM
