Stuck Wheel Bolt, Really Stuck
Old Aug 3, 2007 | 11:50 PM
duhafnusa4's Avatar
Default RE: Stuck Wheel Bolt, Really Stuck
ok same thing happend to me, this is what you do, first drill into the bolt, 1/4 in bit or bigger, then find a stronger bolt with a large head on it. then put that bolt on the laithe and get it down to size to fit into the hole you drilled out,then weld it to the stripped bolt using mig or tig.
Mine was stuck and i took it to a tire place and they put an air ratchet on it!!??!WTF![:@] they were retarded because it just turned it into a mangled mess. So there waas no way to get it off with a socket
My welding teacher helped me out since hes got all the goods
hopefully you know where to use a welder and laithe
good luck
[IMG]local://upfiles/22590/7F7937C96BF94A59BADE5EC6890A46A2.jpg[/IMG]
Trigger200
B7 Models
Apr 27, 2015 11:58 PM
starving030
Jul 21, 2014 01:00 PM
soundquest
Jan 13, 2013 05:35 PM
oceanisbleu
Jul 30, 2009 07:38 AM
tomz322
May 14, 2008 12:35 PM
