subwoofers to stock bose?
Old Apr 29, 2007 | 05:13 PM
willard00's Avatar
Default subwoofers to stock bose?
before i start, ive searched and i looked for an audio only forum. but didnt find either. so i posted this hear. so dont yell at me
i was just wondering how to hook up some subwoofers and amp to the stock bose system? including the stock HU. i know there are adapters and such for doing this, but i dont know which is the correct one to use? any guidance would be appreciated! thanks guys.
Old Apr 29, 2007 | 05:24 PM
akielb's Avatar
Default RE: subwoofers to stock bose?
Disconnect the rear deck speakers and buy a amp that has speaker level imputs - thats the easiest way to go
Old Apr 29, 2007 | 06:25 PM
willard00's Avatar
you dont know the correct adapter to use though for hooking it up behind the HU?
Old Apr 29, 2007 | 06:29 PM
akielb's Avatar
doesn't exist - sorry, the bose system is the biggest PITA there is when it comes to upgrading. there is a DIY somewhere that I saw where someone hacked into the stock amp in the rear and made some RCA's work, but it seemed like to much work for what it accomplished.
Old Apr 29, 2007 | 06:58 PM
Babz's Avatar
https://www.audiforums.com/m_318162/tm.htm
Old Apr 30, 2007 | 02:23 AM
willard00's Avatar
are you sure theres not something like this: http://www.cardomain.com/item/SCOFAI3or this: http://www.cardomain.com/item/PERSVEN4for hooking it up to the stock bose? i could have sworn i read something about doing it with my old nissan which had bose...ide assume it would be the same adapter for the bose in audi's? maybe ill see if i can find that write up again....
Edit- Found it:
nevermind, deleted it...wrong thing.
http://www.crutchfield.com/S-ZQuJBmW...;i=142SLC4#Tab
there we go. thats what i was lookin for!
Old Apr 30, 2007 | 01:30 PM
VitaminB6's Avatar
You need to work on your search skills - lots of people have done this, and there are tons of posts on this subject. Here's a couple:
https://www.audiforums.com/m_409285/tm.htm
https://www.audiforums.com/m_154610/tm.htm
Old Apr 30, 2007 | 01:51 PM
willard00's Avatar
yea i know i do, this forums different then the old one i was on...it'll take some getting used to. but thanks for the links!
Old Apr 30, 2007 | 02:08 PM
new2me's Avatar
This forum helps me out in that area. I like it because you can request diagrams for specific car's and subjects. www.the12volt.com
Old May 5, 2007 | 03:22 PM
sfwjesse's Avatar
I did mine this way. You have a B5 so its perfect for you. My B6 had a different plug on the amp, but i was able to figure it out by wire color (same as B5). This is tough but it is a clean install, and only one wire run front to back. You are gonna have to run your speaker wires as well. Why bother when you already have signal in your trunk from the stock amp, and its already converted to signal only (no voltage).
03ttcoupe
May 14, 2011 12:49 PM
whiteaudiguy
Feb 26, 2010 06:45 PM
mlarco52
Aug 6, 2008 03:22 PM
Ant98Quattro
Oct 16, 2007 11:15 PM
02A418T
Jun 7, 2006 12:59 AM
