SUnroof and IN_1 indicators
Rigth me back again sorted out my power steering fluid.
Now 2 other problems i have.
Still the same car: A4(b5) 07/95 1.8 non turboed
Problem 1: Sun roof - what happened is that i turned the flicker to open the sunroof and tryed to open rear left window as well, waht happened my window is opened fine, and my sunroof to, but i couldnt close the sun roof. What was happening when i was flicking the sunroof switch the roof mechanism seems to do something and makeing noice, but for some reason it didint went back, and no metter what direction i was pointing my switch it would still make a noice like its about to open, but just stayed inside the roof. So i took most of my roof cover apart and pulleed it manualy, cince then i disconected my sunroof switch. Now i would like to fix it, but dont know if its dead, or just some sort of the jam.what should i do?
Problem 2: I dont go to the official Audi garage coz here in Portugal it cost arm and a leg. So i do it myself or i have a friend mechanik that dose most of the complicated things for me, like timing belt and so. On my oem display right under the KM i have indication IN_1 and its flashing for like 20 sec before i can see KM when i start myy car. I know audi uses computer to get rid of it. I dont have a cable to connect car to laptop, so i heard there is a manual way of doing it? Dose anyone knows how?
King regards
MSIMSI
King regards
MSIMSI
as to the first qustion, it probably the regulator that is messed up. mine did similar things and I just don't use it. Probably gonna cost you to fix it to.
As for the second qustion, the "IN_1" is just a schedualed inspection indicator, that goes off at preprogramed milage intervels, It has to be reset my VAG or the dealer. It is also something that I just ignore.
You don't need a VAG or go to a dealership to turn off the inspection alert. Its simple and takes about 15 seconds. Try these.
https://www.audiforums.com/m_131114/.../tm.htm#131465
http://www.automotivehelper.com/topic71405.htm
tariqahmad
Oct 16, 2009 11:49 AM
