SUnroof and IN_1 indicators
Old Sep 19, 2006 | 07:55 PM
msimsi's Avatar
Default SUnroof and IN_1 indicators
Rigth me back again sorted out my power steering fluid.
Now 2 other problems i have.
Still the same car: A4(b5) 07/95 1.8 non turboed
Problem 1: Sun roof - what happened is that i turned the flicker to open the sunroof and tryed to open rear left window as well, waht happened my window is opened fine, and my sunroof to, but i couldnt close the sun roof. What was happening when i was flicking the sunroof switch the roof mechanism seems to do something and makeing noice, but for some reason it didint went back, and no metter what direction i was pointing my switch it would still make a noice like its about to open, but just stayed inside the roof. So i took most of my roof cover apart and pulleed it manualy, cince then i disconected my sunroof switch. Now i would like to fix it, but dont know if its dead, or just some sort of the jam.what should i do?
Problem 2: I dont go to the official Audi garage coz here in Portugal it cost arm and a leg. So i do it myself or i have a friend mechanik that dose most of the complicated things for me, like timing belt and so. On my oem display right under the KM i have indication IN_1 and its flashing for like 20 sec before i can see KM when i start myy car. I know audi uses computer to get rid of it. I dont have a cable to connect car to laptop, so i heard there is a manual way of doing it? Dose anyone knows how?
King regards
MSIMSI
Old Sep 19, 2006 | 10:04 PM
flyboy's Avatar
Default RE: SUnroof and IN_1 indicators
as to the first qustion, it probably the regulator that is messed up. mine did similar things and I just don't use it. Probably gonna cost you to fix it to.
As for the second qustion, the "IN_1" is just a schedualed inspection indicator, that goes off at preprogramed milage intervels, It has to be reset my VAG or the dealer. It is also something that I just ignore.
Old Sep 19, 2006 | 11:02 PM
Trey25's Avatar
You don't need a VAG or go to a dealership to turn off the inspection alert. Its simple and takes about 15 seconds. Try these.
https://www.audiforums.com/m_131114/.../tm.htm#131465
http://www.automotivehelper.com/topic71405.htm
Old Sep 20, 2006 | 04:40 AM
flyboy's Avatar
Its a 95, I'm pretty sure that won't work.
Old Sep 20, 2006 | 01:11 PM
Trey25's Avatar
oh...yea. Get a VAG.
Old Sep 20, 2006 | 10:51 PM
msimsi's Avatar
So the answear is - i have to pay loads of money for the roof and no one knows how to desable In_1 notification?
Malcolm.barton
Jan 15, 2014 08:37 PM
face891
Jan 4, 2012 10:24 AM
tariqahmad
Oct 16, 2009 11:49 AM
msimsi
May 18, 2006 03:41 AM
ichi
Aug 12, 2005 01:46 PM
