Sponsored by:
Sponsored by:
Sunroof sticking
Old 02-28-2006, 07:35 PM
BadMajik's Avatar
Default Sunroof sticking
I was wondering if there is any way to oil or grease to sunroof tracks, or any other way to fix it, when i open my sunroof the further it goes back the harder it is for it to open, it kind of studders when opening, plus it is kind of slow. I dont think it is the clips you can get from ecs because it still opens and closes fully, but it is just kindof annoying. Thanks for any help.
Old 02-28-2006, 07:37 PM
bajamoon's Avatar
Default RE: Sunroof sticking
you can grease your tracks, I do mine about once a year, don't put to much you son't want globs of grease falling off where you can't get it.
Old 02-28-2006, 09:06 PM
CRAZYHAWK's Avatar
Silicone spray lubricant stays clean.
Old 03-01-2006, 02:44 PM
mauricewong's Avatar
i had the same problem. greased it... it went away.
Old 03-01-2006, 03:05 PM
miabhai_freaked's Avatar
actually...mine sometimes makes the sound of plastic snapping when i just chage the
switch to the sunroof lifting a bit (not sliding off)...i couldn't figure out why it's doing
that...almost like some plastic in there was about to break while opening and closing...
what do u think's up with taht?
Old 03-02-2006, 01:10 PM
BadMajik's Avatar
Well I sprayed a heavy coat of silicone on the track and i tried to get back as far as i could, but it seems like it made it worse, and now it gets stuck and stops before it opens completely. I think i am going to try and grease the tracks, but what kind of grease should i use? When i was spraying the silicone i noticed that there was already grease on the tracks, and it was yellowish in color.
Old 03-02-2006, 01:42 PM
InsaneHatter's Avatar
White LITHIUM grease.. do not buy a petroleum based grease as it can eat away at plastics, I had the same problem, and I just tried mine.. working good.. (I greased it like a few months ago, but I havent opened it due to fear/winter)
Old 03-02-2006, 02:12 PM
avanttripleloop's Avatar
be sure to clean all old grease off as some do not mix at all and will turn to a hard wax like craaap
Old 03-02-2006, 04:34 PM
BadMajik's Avatar
Ok thanks i will try that, hopefully it works.
frankellul
09-08-2012 10:31 AM
mrocke440
11-20-2010 09:11 PM
tariqahmad
10-16-2009 11:49 AM
aurbablue09
B8 Models
03-09-2009 06:27 AM
RedTTQ
12-29-2006 03:55 AM
Quick Reply: Sunroof sticking
