Supporting mods for gt28rs?
If I go with the gt28rs, what are the supporting mods that I will need to get, in addition to the turbo? I'd like the extra power, but dont want to spend that much more that the K04.
you could go with a gtrs elim and just have to get new tuning, injectors, and probly a fmic. but if you went with a gt28rs you would need this kit- http://www.atpturbo.com/Merchant2/me...ory_Code=VVWTK plus injectors and software. you will most likely get bored with a k04 (i am). i would suggest saving up a bit more and getting the gt28rs kit.
supporting mods besides the obvious (turbo,software,lines, gaskets testpipe/HFC)
what year is your car?
large FMIC (racetec would suffice) er sport would work but ER comp would be the best... but also the most $.. there are several other options.....
clutch spec 3 or southbend OFE ss or FE SS
people have had problems with the spec and OFE lately
BBK
you really shouldnt just throw on a BT without the proper mods to handle the power... its soooooooooo much more power (about double) , u will need the added braking, cornering, clutch, and FMIC to be safe on the road and deliver the power correctly to the road
even with just a 1+ flash i wish i had a BBK sometimes (but the CD/slotted rotors, pads, motul fluid and stainless lines help)
and couldnt see going without the STaSIS streetsports...... best $800 i spent on the car so far
BBK
